I finally got her running after 5 years! She was running good before I popped a head gasket. Anyhow, I put a set of used heads on, a set of brand new 60lber's, an old 237 regulator-my adjustable has a bad diaphram, a fresh set of NGK UR5's set to .30, a brand new Denso O2 sensor, and a Red's chip. I was dealing for years with 150 pegged BLM's.
When I first started up, I shut her off after a minute because I did not want to spin a bearing for sitting so long. I looked at the FP gauge and noticed as soon as I shut it off, pressure dropped very quickly. My FP gauge is glycerin filled and accurate to within 1%- a grade A gauge! After the 2nd start, I let her run until hot. I shut her off and FP stayed high for a while longer this time. Now I start the car and she's running like a diesal freight train-black smoke, very rich! My BLM's are pegged at 90 and would like some troubleshooting insight. Here are Scanmaster#'s, hot at idle:
AF=6
L8=35-42
Bat=13.7-14.1
Int=100-126-mostly low end
BL=90-I disconnected hose to regulator, no change.
Cle=164-167*
Ats=94
R's=800-925-varies
TPS=.46-I keep it high to get into P.E. mode quicker at WOT
IAC=39-sometimes 10-25 as well.
237 regulator: 40psi line on/43 psi line off.
Vaccuum is 17
Oil pressure is 16psi
I did not check plugs yet. I did unplug MAF with no change in BL, though she did idle a little smoother.
AF=6
L8=35-42
Bat=13.7-14.1
Cle=164-167*
Ats=94
R's=800-925-varies
Vaccuum is 17
