Howdy,
I'm starting to build a Bonneville car and while I'm likely to have a TH350C as starting material, the lack of RPM capacity of the production blocks makes me nervous about trusting a 1:1 top gear and trying to crutch it with a tall rear axle.
Problems are a few. I'm starting with an 81 so no frame extension for a TH200-4R. I'm spending an aweful lot of money on safety gear like a bombproof rollcage, fire systems, and a funny car fire suit; so a full on built unit is not in the cards.
Now on the bright side, traction is not great so I'll be rolling into the throttle and boost. Power is only 300hp target at this point. Car will only make 3mi passes and I doubt I drive it on the street under anywhere near full power with a 3.0L destroker and too big of a carb and turbo. I will be manually shifting it on race day.
Think a stock Cadillac unit would work or do I need to step it up to a BQ or BRF unit?
Thanks,
Thanks,
