SignUp Now!Thanks, i'll google it.Boost Leash on my car. Works great, simple to use. I have CO2 on mine
Bryan
I just checked out the website and its got tons of goodies on there. I've been a member since 2007 and have no clue how i never came acrossHartline performance
Bryan
Great info. thanks. Was it easy to set up the first time you used it? any snags?Solenoids under hood near AC dryer
10oz CO2 bottle mounted with a piece of 1/4" plate steel with a U groove cut into it and skid under the drivers seat belt mounting bolt. The bottle mount is installed using 1/4" thread serts through the plate steel . looks like its bolted to the floor but its not
Very easy install but if needed , Randy from Leash Electronics is very quick to respondGreat info. thanks. Was it easy to set up the first time you used it? any snags?
The Leash and AMS are great if you need stages, ramping, **and** have an external wastegate.
if you still run a stock style gate, and don't need to adjust the boost very often, then an "MBC" like the one RJC sells, (there are many varieties) is likely the easiest way to go. There are several electronic ones that work with stock style gates if you need some features.
To the original posters, what are the wastegate details of your cars?
Bob
