turbonut85
Rarely used member
- Apr 11, 2008
Did you take the lid off the translator?
Yes. There are switches inside, and instructions on the underside of the lid.Nope, I didnt know I had to take the lid off. Is there instructions online that would tell me what to do?
Tomorrow ill see if I can, busy painting rooms in my new house. Also when I tried the translator and LT1 MAF earlier it was more of a temporary setup just to see if it would maybe fix my issue. I have to check at my mothers for an old cold air intake for my old truck sitting in the garage, might be able to use that because the truck had an LT1 in it.Get the translator set correctly for the LT1 MAF.... (3" sensor) then reset the ECM....report back.
I'm also dumb because I didnt realize the BLMs are saved in memory so I probably just need to reset my ECM and it will relearn and not to richen everything up....cross my fivers for tomorrow.
What are the settings on your translator??
Updates?
Yeah there is and I believe I have it setup right, 6cyl, GN, limiter?, option off. Then the base 1 = 10% rich and 2 is 10% lean, I tired both setting and still the same.There should be setting directions on the underside of the translator lid.
