captainron
Reel 'em in
- May 29, 2001
So I’ve done some research on the front brake upgrade options for my T by going through all the posts I could find on the subject . Any of the below upgrades will result in improved braking over the stock system. Getting there is the issue. That said, I’m summarizing the limitations to each of the options as I see it. The objectives are costs, modifications required, and reliability.
1. Over sized heavy-duty single piston calipers and stock sized cross-drilled/slotted rotors – Still results in an under-sized rotor diameter and single piston caliper.
2. S-10 upgrade – Simple interchangeability and can even use LS1 rotors and/or C5 calipers with a bracket, but I keep reading that the sealed bearings on this setup fail often, to the point that the bearing hubs are hard to come by and are expensive.
3. LS1 upgrade – Involves cutting the original caliper mounting ears off the stock spindles, drilling and tapping new holes where the dust plate was mounted, then milling a stock rotor down to the hub so that an LS1 rotor hat will fit over it, then uses a bracket for the new caliper. (extensive machine work)
4. Baer, SSBC, Aerospace – Expensive
Any comments on which of the limitations above is more acceptable or other options for these cars?
