forcefed3.8's
Buckeye Bullet
- May 26, 2002
I guarantee it was floating the valves, not to the point of breaking up, just not making the power ot should have. I ran a 224 cam with the same style lobes with a set of springs with 350lbs open. Took it to 6200 with no issues. The car didnt pick up much power with more boost, and when i pulled the heads apart, the valve stems were mushroomed at the keepers from float. I run the same cam, but with 600lbs open to 7000rpm now, making over 1000hp. I dont think your breaking up problem is valve spring related, but i bet it is still getting valve float.
