Lil Truck
I spend to much time here....
- Sep 26, 2002
Sending 3 testers and some license plate frames.
Tester is easy smeezy...
Step 1.. unhook hose from nozzle.. 9/16 wrench will do.
Step 2.. connect hose to gauge assembly on modded cap.
Step 3.. Unplug 3 bar map and plug in simulator.
Step 4.. turn Ignition to ON and put GAIN on 8
Step 5.. go and sweep simulator from 0-30 psi.. observe pressure and look for leaks.
Should take a few minutes to test the kit in a simple fashion. Wont need alcohol if tank already has as it re-circ's it.
Unless there is a leak
Glad to be a part..
Thank you, happy to be part of the operation!
