Like I stated earlier, there was not enough damage of the cam to send enough debris through the engine to cause and damage to bearings or the turbo.
The rear main bearing verifies that.
My last choice would have been to pull the rear main cap first. If the rear main seal is leaking, which most do not, it is easily determined if there are oil "tracks" streaming from the front side of the flex plate.
There is a critical step when installing a rear main cap and seal besides the side seals, and that is the flat surface between the block and cap which can seep oil if not sealed properly.
Another comment is about draining the engine oil. When servicing my fleet of trucks years ago, I preferred to drain the oil after the engine has not run for a few hours or drain while we did other service.
It can take an hour or so for most all the oil to drain, so the pan plug was left out while we addressed other items. I would then take a quart or 2 of new, inexpensive oil after an hour or so of dripping, and pour this into the engine.
Depending on how much crud and used oil it brings out with one quart, we may use 2 or 3 quarts until I was satisified. Oil was under a $1 a quart then, so no big deal flushing with a new quart or 2.
With extreme service in brutal desert conditions our engine problems were nil even after hundreds of thousands of miles on them.
If the oil pan is off the car, weld an external drain plug bung to allow the bottom crud and last pint of oil to be removed.
A $7 magnetic drain plug is a very good tool for diagnosing engine wear as a magnet on the filter will tell you almost nothing.
