Camaro lowers DO fit our cars they just don't have a provision for the sway bar...if you don't have one or you run an aftermarket sway bar that doesn't use the provision (HR, ATR, Wolfe) then you're fine.
Now you've got me curious as to the difference. Moog shows a K6177 from '78-'87 on a G body & K6253 on an F body '82-'92 & K6109 on F body '73-'81. Must be one of those "different but the same" things? Possibly a different hardness of bushing?
Use the 1LE Camaro bushings (90-92). For the lowers in
the rear - #10164152, for the fronts you have to buy the lower
control arms to get the 1LE bushings. The aftermarket ones
are NOT the hard rubber.
Larry.
(Thanks to BlueHog @ montecarloss.com )
