My heads are up at Andy Jensens shop to be repaired. (The shaft pedestals are cracked)
Andy wants to mill off the factory pedestals and make new ones out of steel. He asked if I could get a roller rocker setup with the shafts already drilled bigger for 3/8" studs, instead of the normal 5/16" fasteners. He seemed concerned that the aftermarket shafts may hardened and difficult to ream/drill.
Does anything like this exist ? or do I need to make a special request ?
Or... are the shafts soft enough to drill ?
Thanks in advance !
Thanks in advance !
