I see these numbers,
1 209 2 204
3 221 4 214
5 221 6 222 as cfm per runner.
And now, how does the power plate affect these numbers? And theoretically, if I were to match every runner exactly, would the need for the power plate be lessened to any degree? I know that the imbalance is largely due to the dog house design but would this help out any?
I also see that on the stock manifold, the numbers start to flow higher as you travel rearward:
1 161 2 157
3 175 4 160
5 177 6 172
So was this part of the original problem with the rears flowing differently than the fronts, and the front leaning out/running rich as a result? What if you ported a stocker, so that these disparities were reversed? Port it so that it looks like this:
1 204 2 204
3 202 4 202
5 200 6 200
True, you're limiting your airflow to around 200 cfm, but would there be any gain from the overall tune being more even under wot conditions? Would a manifold that flowed like this be able to eliminate the power plate altogether? Has this been attempted?
