Looking for advice on my buildup I am considering doing, I am trying to build an engine out of a bunch of parts as cheap as possible to get my GN back on the road again. Then I can pull my engine that is in the car and Very tired and do a nice forged roller motor. My goals for this first engine I want to do now is to stay on a tight budget but run 11.00's with either alky or race fuel? If it will run high 11's on 17 psi street trim I will be happy. I want to do the 2 center billet caps on a 109 and use stock crank, mains ground .010 stock rods prepped with arp bolts resized, .020 speed pro hyperutectic pistons, flat tappet hyd. cam and I am going to port a set of 8445 heads, new manley valves springs ect. And possible port the lower manifold. I have a front mount precision and a TE63-1. I am going to pull the front mount and put a neck kit on a stock intercooler and run a ta60 turbo on his combo. Any suggestions? Are my goals obtainable?
