86 MCSS NA
- Mar 26, 2013
FWIW, I purchased a 2004R Street/Strip transmission from CK on Feburary 6th of this year.
Just to give something as close to "apples to apples" for fty_swede to reference to (I'm not sure which exact transmission build you purchased).
Here are the pressure readings I have:
NOTE:I had idle set @ 1100 rpm in Park/Neutral which dropped to 800 rpm in every forward gear and Reverse with foot brake applied.
NO TV (TV cable unhooked from carb)
P- 65 psi
R- 135 psi
N- 60 psi
4- 60 psi
3- 60 psi
2- 175 psi
1- 170 psi
FULL TV (TV cable pulled out fully by hand with cable unhooked from carb)
P- 280 psi
R- 285 psi
N- 275 psi
4- 265 psi
3- 260 psi
2- 175 psi
1- 175 psi
Hopefully this helps in some way.
EDIT: I see that my results may not be 100% helpful since I only have my 10 year old son to help while dong this. I didn't set the idle up to the exact RPM(1100) with him in the car holding his foot on the brake and shifting gears. I will have to try and get better readings sometime with an adult in the driver's seat.
P- 65 psi
R- 135 psi
N- 60 psi
4- 60 psi
3- 60 psi
2- 175 psi
1- 170 psi
P- 280 psi
R- 285 psi
N- 275 psi
4- 265 psi
3- 260 psi
2- 175 psi
1- 175 psi
