CK built 200-4r pressure readings
FWIW, I purchased a 2004R Street/Strip transmission from CK on Feburary 6th of this year.
Just to give something as close to "apples to apples" for fty_swede to reference to (I'm not sure which exact transmission build you purchased).
Here are the pressure readings I have:
NOTE:I had idle set @ 1100 rpm in Park/Neutral which dropped to 800 rpm in every forward gear and Reverse with foot brake applied.
NO TV (TV cable unhooked from carb)
P- 65 psi
R- 135 psi
N- 60 psi
4- 60 psi
3- 60 psi
2- 175 psi
1- 170 psi
FULL TV (TV cable pulled out fully by hand with cable unhooked from carb)
P- 280 psi
R- 285 psi
N- 275 psi
4- 265 psi
3- 260 psi
2- 175 psi
1- 175 psi
Hopefully this helps in some way.
EDIT: I see that my results may not be 100% helpful since I only have my 10 year old son to help while dong this. I didn't set the idle up to the exact RPM(1100) with him in the car holding his foot on the brake and shifting gears. I will have to try and get better readings sometime with an adult in the driver's seat.
86 MCSSA,
Your pressure readings look more or less exactly like mine. I also have a street/strip transmission from CK. Thanks
What I would really like my tranmission to behave like is:
1. Full pressure no matter the TV position on D1, D2, D3.
2. When D4 is engaged I would like line pressure to be dependent on TV position.
I didn't ask for this when I bought the tranmission, but I realize now that this is the way I would prefer to have the transmission.
If the above is not possible I would like to have full pressure >250psi on D1, D2..
