Converter Info
Nigel
Looking to get some converter numbers for those willing to post. Looking only for 1/4 mile numbers. Even though it may not be the perfect way to check slip only interested in time slip mph and logged rpm. This is a good way to see converter performance. My next one will be a NLU, but would like to see how performance stacks up. Basic combo info would be good to if not in your signature.
Converter – Husek 3021 9.5 LU
Zero Boost RPM – 2300
1-2 shift RPM – 5500-4750
2-3 shift RPM – 5200-4650
Trap RPM – 5800
Time Slip Trap Speed – 120.14
Trap Gear – 3rd
Rear Gear – 3.42
Rear Tire – 255/60-15 MT drag radial
Car Weight - Full Weight (Never Scaled)
Same Husek 9.5'' 3021LU converter. Built trans myself (BRF)
1-2 shift 5200
2-3..........5350
Trap RPM in 3rd 5380
3.42 factory gear
Rear tire 275/60 Pro Radial
11.46 @117
Stock motor and heads (120K miles) with comp 980 valve springs. TE60 AT 26-27 PSI Razors alky
Thanks gusszgs. Only question is are the shift rpms 4200, and 4350? If you are in my condition, a couple of martinis into vacation, the digit off is understandable. :)
Not sure what your talking about. My car shifts from 1st to 2nd at 5200 and 5350 2nd to 3rd. The shift RPM'S drop to around 4500 or so if that's what your referring to.
Sorry, yes. Looking for the RPM drop after the shift. So the minimum RPM after the shift.
1-2 shift RPM – 4750
2-3 shift RPM – 4650
Trap RPM – 5800
Trap Gear – 3rd
Rear Gear – 3.42
Weight of the car?
PTS 9x11 footbraking 2800@0 boost
1.65 60ft
7.15@96.4 1/8
11.25@118.7 1/4 120.6/locked
1/2 2/3 shifts are 5,100 400-500rpm drop on shifts
Around 5,500 at the mark
20psi
Converter: 3021, 9.5", LU
1-2 shift: 5150-4700
2-3 shift: 5400-4800
60': 1.545
MPH: 100.85
Rear gear: 3.42
Rear tire: 255/60-15 MT ET Street drag radial
Car weight: 3650 w/driver
Art Carr 16930
Shift Point 5800
60 Foot 1.5x footbrake
ET 6.7 1/8th Mile
MPH 1/8th Mile 105
Trap RPM 5500
Car with driver 3480
MT 28x9 slicks
TT 5.7 112 Race chip
Are you guys with 200r4 transmission manual shifting or letting the trans shift on its own?
0 2800
1-2 5750-5100
2-3 5650-5100
5750 at 1:1 29” slick
135.8mph 3600lbs
3.42
0 3000
1-2 5800-5300
2-3 5700-5400
5850 1:1
140mph
29” slick 3650lbs
3.42
Let her shift as needed
Thanks for the replies so far, hopefully we can keep it going.
