In the middle of doing head gaskets on my GN. After cleaning the block and head sealing surfaces, I used a straight edge and feeler gauges to measure flatness.
The question is - how flat do they need to be using this measurement method?
In other words, how thick of a feeler gage would you feel comfortable allowing to fit under the straight edge when it's laid across the head surface (or the block surface)?
I have this recollection that .003" maximum is the spec, but I can't find confirmation anywhere. For what it's worth, I'm using Fel-Pro 9441 PT's with ARP studs.
Thanks,
Thanks,
