Dave Bamfords 369 LSX Block Twin 70mm Precision Turbos
beautiful, i like the weldon regulator, im sure you got a big ass weldon back there somewhere..
Thanks guys! The conversion was a pleasure!
Fuel pump is a Weldon 2035 pumping the E85 to 160 lb injectors.
I will start saving money so I can be first in line when u sell it...
This thing went together much cheaper and easier than any Buick
lsx block 2k
Eagle crank rods weisco pistons 3k
Cnc ported junk yard ls1 heads new valves and springs from trick flow 1k
Machine work and assembly of motor $1500
Much cheaper than the 20+k V6 time bomb.
The ac compressor? I'm not sure where it mounts on the 5.3 truck, if it's low on the right side it won't fit.
