You should get yourself a Wide Band O2 setup if you want to tune seriously.
A narrow band (what came in these cars stock) O2 sensor is only accurate at 14.7 to 1. Anything richer or leaner than that is affected by exhaust pressure and temperature. They are notoriously inconsistent as well. One sensor's .780 may be another sensor's .900 and so on and so forth. The only point they are accurate is at 14.7 to 1 which iirc is about .480 or .450 or so (been awhile since i messed with them)
When springtime comes, on go 65# injectors, Razor's ALKY system, Powerlogger, new TT chip, 3 Bar MAP, Wideband O2, Duttweiler necks for the intercooler, an RJC powerplate, BIG MOUTH cold air intake, A/C delete pulley, driveshaft loop, pinion snubber, another airbag, S-10 wheel cylinders w/ prop. valve, var. rate rear springs, MOOG 3/4" drop springs in front, Edelbrock adj. upper control arms, new bilstein shocks all around, Kirban rear seat X-brace, additional frame bracing from 81 Grand Prix, and custom braces to tie together the front and rear of the frame.
3200 stall (not sure yet which one), adj. roller rockers, and if I get the money and the time, perhaps a complete roller cam and a nice head and intake job (ported to match), and a slightly larger BB Turbo. Would have to sell mine first to be able to afford it.
Would like to replace all the wiring and add a new turbo guage, EGT guage (may not need it as I am told powerlogger can sense this), Tranny Temp guage (forgot about the tranny cooler), and get the oil pressure guage working. Have ordered a 140 MPH factory style Monte SS speedo.
For dress-up Turbo 6 turbo shield, and all the factory turbo emblems, new turbo 6 hood insulation, and custom embrodered floor mats and trunk kit with th e tubo six logo. New wheel inserts with the turbo 6 emblem. Am installing an external Kenne Bell Fuel guage as well. Also would like to build a laptop stand of some sort. And if I can find a factoy GN engine harness, I'd like to re-do most of the wiring.
Will be running a mix of 50/50 E85 and Meth on top of that.. No need for race gas at $6 gal ever again. And no more toluene, thank god!
Expecting consistent low 11's and although I may be dreaming asking for 30 mpg at $2.39 a gal for E85, I think it may be possible with everything I have listed.
Wanting to repaint the car Corvette Artic White with all the original stripes. And going to add a couple other emblems.
Will be removing all the trim, and painting the jambs etc.
Anything else I should be adding?
Car will NOT be for sale when all of this is done, and may be one of the coolest and quickest Monte SS's out there, and no one will have a clue whats under the hood
. Will still look all factory, wheels and all..
Not going to touch the interior, its all factory and in great shape, bench seat and all.
But don't worry I am not limited to slow ass Monte Carlos, I am on the lookout for a 86 WH1 to my liking, its gotta be a bench seat with a Astroroof.. I wanna install GN wheels and GNX guages.
