Rob,
Several members have indicated no major problems running E85 for several years now. I'm not so much worried about about the intake manifold as I am my Champion aluminum fuel rails and fuel pump/FPR. I am ready to upgrade fuel injectors, pump and FPR so I don't run out of fuel and just "go for it" and see what, if anything, fails long term.
Since E85 requires ~30% more volume, you need to look closely at the capability of your fuel pump and pump wiring. The pump will have to put out more pressure to move the additional volume of fuel through the supply and return lines. Unfortunately, fuel pumps don't work that way...as the pressure goes up, the volume goes down! If you have an excess of fuel pump capacity, you may be ok. You need to run some calculations to be sure. Be Careful!!
Did you see the Mar 08 issue of Car Craft? There is an article entitled, "Seven Cars: 9,565 Horsepower". Page 77 contains the following sentence (next to the last pararaph, the last sentence), "This ethanol (E85) blend was especially helpful for the supercharged and turbocharged engines because of E85's outstanding ability to pull heat out of a compressed charge."
All of the contestants ran E85!
Conrad
Conrad
