The fuel system is everything on these cars. The injectors are only one part. There is allot to go wrong down the line. You have a fuel pressure regulator and a fuel pump that needs to be working correctly.
You can't guess. You need to test. Yes? :biggrin:
Is the fuel pump and regulator stock?
These are some important questions, and Rick is 100% correct.
You can't guess, unless you like playing Rusian roulette.
......... Sorry if that sounds defensive, it's not intended, I certainly don't want to make the same mistake twice. So, as of right now the plan is (as mentioned above): Engine reassembled, test voltage on injector harness, test FP again, upgrade to 87 ECM w/TT chip and MAF, add a PL. Anyone think we should do something different?
No offense taken in your post, just a good tech discussion to get to the root cause.
There are two measurement needed with the fuel system; Pressure and volume. When the pressure increases, the volume decreases. We need to make sure you have pressure when the volume is needed since the fuel system “leak” is controlled by the injectors. This is the easiest way is the determine adequate pressure at XX boost. Example; The base fuel pressure is set to 43 PSI, line off. At 10 PSI boost you need to see 53 PSIG FP, at 20 PSI boost 63 PSIG FP (Line on of course). This is what guys refer to as: "FP rising with boost"
(Note(!): The stock FPR will not read 43 PSI line off, unless it has been upgraded)
If you don’t see the higher pressure, there is an issue that needs to be resolved. Some of the variables that affect FP are; Fuel pump, system and pump voltage under load, bad grounds, plugged filter, crimped line, defective FPR, inadequate or limited boost/pressure signal to the regulator, low fuel level, etc.
The only thing you did wrong was not monitoring KR. If you were, once you saw the KR, it would have warned you to get out of the throttle tp prevent damage at the lower boost levels.
My concern are the ring gap, and the KR sensor/module, but I don’t know. My logic is; If the KR system is working correctly, it would have probably pulled enough timing to just blow a HG, especially with a stock chip. Chuck Leeper who posted in this thread is one of the guru’s and could give a much better idea looking at the pics.
Throwing $$$ at these cars will not make it run better. The tune is everything. You do not need a MAF, until you determine it to be faulty. (PL will help you do that
