After playing around with my other cars for the past few months, the T Type is back together. I had issues leaning out the #1 cylinder and after some investigating my guess was that the inline fuel pressure regulator on the Champion fuel rail was giving me problems. I had upgraded from a single fuel pump to a double pumper but the problem was still there. I checked the flow of the injectors and they were fine.
I decided to upgrade to an external fuel pressure regulator setup while also dual feeding the fuel rails and upgrading the fuel line with plans to use the stock fuel line as the return line. I bought a driver's side Champion fuel rail setup for an external regulator, an external regulator, and teflon racing hose and fittings. I went with -8AN fuel line split into two -6AN lines feeding the rails from the rear. Paul (Pacecarta) installed the setup.
There is a Y block located under the car where the two -6AN lines meet. It was too tight under the coil pack to put the Y block there. The fuel filter is tucked in on the frame. Mounting the fuel pressure regulator on the Champion AC delete bracket I think gives it a nice clean look.
Take a look:
Take a look:
