BEATAV8
The Engine Whisperer
- Feb 14, 2002
There was ample space between the tank and the truck floor for all the fittings / hoses.
SignUp Now!Agreed, it will have a relatively short life. I'll be swapping it out at least once per year, which for me is only a few thousand miles anyways.Looks good, only thing that would worrie me is, the filter media sq inches. Those filters are pretty small, the 100's wont catch much like you said except rocks but the 10 might get dirty and need to be cleaned/changed often.
Naughty naughty Prasad!Oh Steve, you're such a bad boy!!!!! LOL!
Looking good, are those braded lines E85 proof? Do they have teflon coating on the inside?
Prasad![]()
It looks like you are running your fuel lines on the driver's side, opposite from factory? If so, got any pics on the routing to the engine compartment? Did you remove the stock lines? Thanks
Cool! Let us know how it runs. What do you set your base fuel pressure at?I leak checked the system tonight. Looking good. I was thinking it might have a leak somewhere after assembly but it's nice and dry.
With one pump running (either one), the system regulates to 49 PSI steady. With both pumps running, it regulates to 51 PSI steady. This is with the engine off. Seems the Accufab is capable of dumping the flow adequately with the -6 return line.
With the engine running, the pumps will be a bit stronger (more voltage) but I expect the system to still be capable of regulating either way.
Before the upgrade, it was at ~46-47 psi. And fuel pressure was really messy when the 2nd pump came on.Cool! Let us know how it runs. What do you set your base fuel pressure at?
She's a Runner! Still have some odds and ends to tie up then take some data.
Then I gotta open the trunk and let Prasad out. He needs to be UNtied.....
Naughty Naughty Prasad..... Pervert!
Great!! Let us know how the car feels. Don't let him out yet, just make him clean up the mess you've made and put the tools away. I need to work on mine but have other friends to help first.
Restrictions built into in the stock supply and return lines, including the single feed tube coming through the fuel header. I think it was popping the relief valves in the pumps, and bouncing the regulator at the rail. Pressure at the pumps was probably 100psi, just to get 70 to 75 at the rail.do we have an idea why the old setup was "ratty"?
Bob
