SignUp Now!can you use a spring loaded cam button for a Ductile Roller cam? I seen this button and not sure if it will work? CLOYES Part # 95189 if so is it just drop in and go? Or do you still need to measure clearance?
In a similar thread, I stated we have built MANY roller engines with ductile cams using a roller button, and there is no need to measure clearances.
Not sure of the Cloyes part, but TA Performance has the one we use, and it may be similar?
I built one that way and had a couple customers do it. All three the cam moved forward enough to have the lifter catch the edge of the next lobe. I engine was saved, two were destroyed. It is not hard to measue it, for me it not worth the potential meltdown
Mike
there is no need to measure clearances.![]()
Nick, I never thought I'd hear that out of your mouth.
You are right!
I used the wrong word?
As I said above, you should check cam lobe-to-lifter "clearance". it is easy to see if there is an interference problem.![]()
Mike
nope that's a ductile cam and I know other guys who never had a problem but I just had a guy a month or so ago who killed a motor so it really had nothing to with old or new as the old "wide" cams were from many years ago. ATR used to use a spring button with some of their early billet rollers, some had problems, some did not. YMMV but the correct cam buton is not an expensive or tough to install part, not sure why you would want to risk a motor using the wrong part for the job?
Mike
