These are normally used for the somewhat heavy hitter stage motor applications. But not always.
The pump is set up to draw oil externally through hoses from the pan (usually a fabricated aluminum sheet metal pan). Then pump it through a relocated filter set-up (like a Precision Turbo Saver). After that, it returns to feed the engine either in the front or back (depending on what stage motor you use) and also feeds filtered oil to the turbo or (in my case) two turbos. I also run the oil through an external cooler as well. Base pressure can be adjusted using the allen head bolt and lock nut on the side. Bypassed oil can be returned to the pan or used to lubricate the cam sensor gear or timing chain. I don't believe Duttwieler makes or brands them them any longer. But the design is still available from others like TA Performance.
General set-up, lots of hoses, custom oil pan, usually make this overkill for a stock type set-up.
