Street Lethal
Tech Anarchist
- Oct 8, 2006
KrisW said:I absolutely will not be able to use my engine harness, will I? Since I have a maf 2.8 right now, I will need to hybrid-in a harness from something else. I'll need either an 86-87 GN harness, a Turbo Trans Am harness, or an 88-94 3800 car harness? The run of the mill GM 3800 harness will be the easiest to get, and I am considering buying a whole car for the odds and ends and extra parts. Is there anything else special I will need to run this ECM in my 88 Firebird?
Your stock harness for the '302 V6 ECM found in your bird can be repinned through 11 wires to run the V8 '165 ECM, so there should be a way to repin it to coincide with the '7148 as if you were starting with the turbo buick harness from scratch. Try not to target an actual turbo buick and/or TTA harness as that can get expensive. Remember that the MAP sensor signal in the turbo buick is just for the boost gauge in the cluster, and the ECM does not even see that reading, just the MAF reading, so it shouldn't be that far off to begin with to your stock MAF harness. However, I do believe Bob mentioned being able to use the '8523 and '8264 found in the earlier 3.8/3800 V6's, which can be had for very cheap at the salvage yards, but let Bob confirm that though....
