- May 28, 2001
Ok so how much?
SignUp Now!Ok so how much?
It would be fantastic if there were real nice install intructions for the 7148, similar to those for the P4, but haven't seen any yet. Such a set of instructions would give a person a much better idea whether they want to tackle the install themselves. Just saying the install is similar to the P4 instructions doesn't do much. There's NO similarities.
Great work so far. Just post up pictoral instructions for a 7148
There are those who use an external waste gate to control boost. Will the EBL throw a trouble code if its not controlling boost or is it something that can be enabled/disabled in the program?
Does the EBL need the VSS signal to work properly? I ask because with a VDO dash the VSS is no longer connected to the harness. Is there a fix for that? My car like most is modified ( vastly ) from a stock car with an untouched wiring harness.
How will the EBL control an alky control kit? The alky control kit has its own control unit, how does the average joe wire it in to the EBL? That alky pump could be the second fuel pump in the EBL too.
I know in advance the FAST wiring harness has to come out in order for this to work correctly.
I apologize for the questions........I'm trying to think ahead here.
...The '88 - '91 VIN C cars used this ECM...
...Email me for the '7148 to EBL SFI-6 re-pin guide if you go this route...
RemoveBeforeFlight
I hate to throw flies in the ointment but how do you run a 1 bar and 2 bar map long with a 3 bar map for an alky system? 3 sensors is overkill but do we have the EBL run the alky system? How would that work?
At the most only two MAP sensors can be used. The main MAP sensor can be a 1, 2, or 3 bar dependent upon the requirements (N/A, 15 psi, 30 psi, respectively).
When running a 2 or 3 bar main MAP sensor an optional 1-bar MAP can also be installed & used. When not in boost the EBL SFI-6 ECM will use the optional 1-bar MAP sensor for the best in driveability. Then once in boost switch to the 2 or 3 bar main MAP sensor.
When running a 2-bar main MAP, the optional 1-bar provides some degree of better driveability (small but noticeable). This option is really intended for those that run a 3-bar main MAP sensor. As the resolution and range of a 3-bar MAP is limited and it makes a real difference.
For an alky system, the EBL SFI-6 has a PWM output for the pump. There is a calibration table based on boost MAP and RPM for the duty cycle (DC%) of the pump driver. The calibration definition file along with the EBL SFI-6 firmware is set up for it to work with either a 2 or 3 bar main MAP sensor.
There is also a priming run input (momentary switch), along with a DC% modifier to this table via a brake switch input.
RemoveBeforeFlight
So compared to the fast system where do you think it holds up? Been thinking about going that way but after seeing this i may be changing my mind.
Is there a big gain over running a chip and a Gen 2. Does it have a malfunction code feature like the scanmaster does?
