slimtastic
yea dude...I rock
- Aug 9, 2002
at this point ive only foun one item that is out of wack, after degreeing the cam in the car i found that the "installed intake centerline" was around 115.5 to the recommended 112 in comps catalog...putting me 3.5 degrees advanced if im reading the degree wheel right.
would this ammount of "advance" kill the potental power at my new 5800 redline? though an advanced cam helped lower the power band.....
what fuel were you using?
You have a turbo on there that will support 650hp and are running it at about 415hp. I dynoed and raced a stock as assembled from GM bottom end last summer and it made considerably more power at 15psi with a lot leaner tune than you are using. GN1 heads and 212/212. I did have timing optimized for the fuel i was using though. If i recall it made around 400whp@15psi, 465whp at 18psi. Around 530whp@20-21psi and 609@25psi.
