SignUp Now!Tandem in series, or parallel?Try WIX next time ... tad more .. but overall a better filter .. run tandem if you don't mind a little extra work
Any pics. Of a setup like this?Parallel
Factory fuel lines with drilled out fittings are pretty adequate unless they have damage. I guess the Racetronix Teflon line kits are pretty reasonable cost wise. Haven't checked myself though...Doesn't apply to you, but many people are buffalo'd into buying that expensive Teflon hose when ya don't need it. Been over a year with braided rubber lines and they don't look like jelly! Matter of fact, I pulled one tonight and rubbers holding up pretty good.
I hate getting hosed! I guess their complete kits are like $400. I was just on the LS1 Tech forum. Seems like those guys are way behind this board on the whole e85 thing...Compared to SS braided, people are getting hosed... Literately
Ya something like $400, which aint bad at all for a complete setup.
Most of the braided stuff is nitrile rubber. Lookie here:
http://iqlearningsystems.com/ethanol/downloads/Ethanol & E85 Material Compatibility.pdf
Im not saying that. Im saying you can get by with cheaper, but there are myths about that way......That I have personally busted and the info above concurs.So we are saying the Racetronix fuel line kit is overpriced? Or is it worth the price?
Looking on replacing my stock fuel lines. Will definitely get their AN sender though.
I think with the Racetronix setup your paying for the convenience of the kit. I think it's worth it, but you can definitely save money if you put something together on your own. $400 is pretty reasonable...So we are saying the Racetronix fuel line kit is overpriced? Or is it worth the price?
DANG !!! I'm gonna have to take off my stock intake and find a cast iron deal before it melts away .. I also need to make sure to keep a close eye on pan gasket cause that's cork ! it should start leaking at any point being its been on E85 since 2004 and oil taking on ethanol like a magnet .
Or some other unforseen circumstances. Like something you didn't know was in the tank.Ya, I've never seen any issues either. I am thinking there are different degrees of incompatibility. Perhaps if raw aluminum or brass is submerged in heated ethanol for an extended period of time then it will oxidize to some degree and therefore they deemed it "incompatible", but in real-world use there's nothing of consequence to worry about.
Cause you shop at Jegs..lolI think it's a nice kit and you get a lot for the price. And using SS braided nitrile (which is indeed 100% ethanol compatible) isn't going to be a whole heck of a lot cheaper. I use SS braided nitrile on my car (Jegs hose) and it was fricking expensive!
I was counting on Vern for a loan but it didn't come through!Cause you shop at Jegs..lol![]()
He's too busy pulling his gas tank all the time.I was counting on Vern for a loan but it didn't come through!
