Nakamichiman
- Sep 16, 2012
Just was curious what has to be done to run 120lb or 160lb injectors with a stock ecu on a power logger. I'm about at the limit of 80lb injectors.....I have enough fuel supply with a double red pump....but injectors are starting to max out.....car has been 6.98 through the eighth.....
If hi-z injectors are used will that make it easier....
Where is the best source for these injectors...thinking 160's but maybe 120's
