I made it to the dyno today here is my combo. What do think you?
4.1, stock P&P heads, 70mm throttlebody, accufab doghouse, te69 turbo, 3' TH downpipe, 83#inj., aeromotive 1000 fuel pump, erson cam, ect...
I ended up running 24# of boost with 25 deg. timing I would of liked to run more boost but ended up running out of injector. This was in 83 deg. temp. and fairly humid out. What do you think it will do with a bigger turbo & injector and on a cool day? 500.3hp & 469.2trq. to the tires what does that equal to the flywheel with a 400th?
