highboostgn
- May 24, 2011
So after tearing down my motor installing ported heads,ferrea valves,110lb springs, a 218 cam, champion intake, 72mm tb and after the break in period and a few hundred miles on the car I took it to the track. The car pulls hard(only on 15lbs) but will only go to about 4500rpm and then it shifts
Im now thinking it could be a motor issue or trans issue... Its running 10.1 afr (it could be lower because I belive thats as low as the autometer wideband displays)
