Educate me on the BB Two step.
Ok I am hooking up the purple wire from the alky kit. BUT before I hooked it up I checked the wire with my meter and it had 12.00 volts.
Here we go.
Forget it
With the alky turned off or the ignition switch on off it (purple wire) puts out ground but once the unit is powered it drops to 3.35 or so.
Ok purple wire is hooked up. Time to play with the 2 step again.
i hooked up the ALKY to the same wire that the two step trigger is on and thats not working. The two step activates with just the ALKY wire and the Trigger not even being activated, i am guessing that the volts in the ALKY wire are enough to activate the 2 step.
Going back to the drawing board maybe using a relay to separate the circuits.
Tomorrow is another day and so is the next.
