TURBOPOWERED68
David
- Jan 31, 2006
thanks for the link i looked over there and i couldn't find it- i should open my eyes next time LOL
Have you worked with one of these things (BB two step)
SignUp Now!Theres videos of it building boost on a buick in park.....Here ya go bobs original thread look at the vids....http://www.turbobuick.com/forums/general-turbo-buick-tech/305322-2-step-stock-ignition-systems.htmlGreat info. Anyone have any before and after results? As in "without the 2 step, I could only build xx PSI at the line, but with the 2 step I now reach XX."
Also, the comment on transbrake now obsolete, this is because the motor builds the boost, but won't push through the brakes as mush as trying to build w/o the 2 step?
Pretty amazing product, now that I somewhat understand it.![]()
I don't know if it will help build boost...although it might because you can retard timing at launch which can help some cars. Also may be the banging on the rev limiter may help to, just as the stick shift turbo guys use that antilag setup to create back fires in the headers to get it spooled.
You could wire it to the brake lights or the shifter. Make 1st low have a switch that activates it. Or just put t on ad button and let go when you launch the car.
dave it has to go to the cci 12v source as instructed as it powers the two step and also interupts the power going to the CCI module allowing the two step to function
being a hybrid if you dont have a cci fuse ( you should on the casper harness) you could then cut the the power feed to the cci and install two female spade connectors, then plug the switched feed side to one side of the fuse holder and then plug the other end of the holder to the side that goes to the cci unit
is it a caspers engine harness?
The ignition module has 2 wires that feed power. The 2-step needs to be connected in line with the wire going to pin M. (and NOT pin P)
Bob
Bob's 2 step allows to build all the boost you want without making a ton of power. It works very well. IMO it makes a trans brake obsolete.
