- Feb 18, 2006
Without a trans brake you're preloading the suspension. :aunching off a trans brake is much better.
Like to hear Bob's take on this.
SignUp Now!Without a trans brake you're preloading the suspension. :aunching off a trans brake is much better.
Use a a relay to turn off alky during 2 step activation. Use the same wire that turns on the 2 step to activate the relay. Hook up relay to the the map sensor wire of alky system. Intersect that wire. I'd hook those wires up to the normally closed side if the relay. Then when activated, the relay switches to open and breaks the Map sensor circuit, which will turn alky off.First step questions.
1-How do i determine RPM setting?
2-How is the best way to determine the RPM cut out and weather full cut or partial cut?
3-How much timing retard should i run?
4-How do i determine how much retard to run?
5-I am getting some KR when on the first step, if this normal?
6-The Alky is spraying while on the first step, should i change the Alky settings so that it comes in later?
BTW the above questions are all for the first step.
Thanks for your help.
partial cut and full cut modes arent for two step , they are for main rpm limiter
i was just told about this a few hours ago.Isn't there a input on the controller you can ground to reduce output while on the 2 step?
I will get this done in the next few days.grounding the purple wire to the pac will delay (reduce) the alky spray while on the two step
Thanks for your help.The way I explained is to cut alky out all together on the 2 step
got youThat was the way Cal h wanted it set up on a mid 9 sec car I put together for someone that he tuned. I guess he didn't want any alky at spool up
