bmackinnon
- Feb 24, 2005
Looks fantastic! I would ****can the volt booster, however... :wink:
SignUp Now!One of 'em sends the temp info to the ecm, and can't be removed.... I 'think' that is the one.... someone who knows for sure will chime in, but make certain because you will likely want to resolve that issue while the motor is still out.... i'll search around and see if I can find the definitive answer....
edit: that location is all good, idiot lite will be non-functional.... quote from one of my own posts:
"There are 3 temp sender/switches on the intake...
1) hi-temp fan overide switch (top of intake, behind AC compressor),
2) temp sensor for data to the ecm (front of intake, on the rite looking from the front), and
3) 'hot' idiot lite temp switch (front of intake, directly to the left of the upper rad hose)... you can use this one for a gage sender location (adapter may be required) but of course you lose the idiot lite functionality... this is where my mech. temp gage sender is installed... some people 't' a gage sensor in here also, so as to retain the idiot lite, but it's kinda cheesy with a 't' connection and not that easy to fit it all in there as I recall.."
Thanks. I still need to do a few things. The downpipe to to turbo is leaking. I put my hand over the joint and can feel the exhaust puff. Do I need a gasket? I thought someone said just use hi-temp silicone.
Another thing. I put everything together and saved the crank sensor for last. I started tightening the bolt that holds the sensor and it was stripped! All I did is get a nut that fit the screw and there was enough "tail" on the end that I could reach up and hold the nut on it while tightening. Worked perfect and if I was to do another build I would drill out the threads and JB Weld a nut on the top of the crank sensor clamp.
Vacuum/boost gauge is not working either. I think i pinched the tubing when putting together the gauge pillar.![]()
Good to hear your oil pressure /bearing clearances are tight. Precision Machine here in Birmingham gave me 3-5 thou on conn rods...guess they didnt like me telling them to please give me tight clearances. they also knocked over my polished stock crank and then insisted I pay for a grind job. Absolute fools are out there in the machine shop biz.
