pmoore4321
 - Jan 10, 2010
Thank you!  That is exactly the info I was looking for.
	Charlie, if you're talking about your 4.1 build make sure you have at least one of the 3 grooves.
I had to manually groove my block on my 4.1 as I'm running a roller.
	I was thinking about groving my blocks as well Earl. How hard was it?
	I'm a big believer in porting the oil passages in the timing chain cover. Is yours ported? If not I'd pull it off now and do that. Setting the oil pump gear clearance is important too. It needs to spin freely but with a minimum of up and down clearance. I also make sure there is no timing chain cover gasket overhanging the two oil passages that run between the timing chain cover and the block. It seems like every gasket I have ever used has holes smaller than the passages and I have to trim the gasket to keep it from being a restriction.
Using a roller cam or hydraulic? If roller, got the end play all set?
When installing heads, I had 3 pushrods that would kiss the heads. I never noticed it until I was doing a cam swap and wondered why there was a shiny spot on a few of the pushrods. I had to open up 4 of the pushrod holes in the heads, two on each side, with a rat tail file. Would have been a lot easier to do that before I had the heads bolted down for good!
For that matter, I have head studs, and apparently one of the bolt holes in the block isn't quite perpendicular to the deck surface, because when the studs are installed the head on that side wouldn't sit down flat. I had to open up that one bolt hole in the head so it would sit flat on the block. I didn't want part of the head bolt torque going into pushing the head down over the stud, instead of doing its job of clamping things together.
Did you remember to put the oil slinger back on before you got the timing cover on?![]()
That's all that comes to my mind at the moment - hope it helps
John
	Is this location OK for the water temp sender? I removed the sensor that was in that location. Is that going to throw an idiot light on the dash?
