turbobob924
- May 28, 2001
I have been chasing an error code 34 all weekend.
Translator plus, 3" LT1 MAF
Extender chip with MSD 50's, TE44 turbo at 22lbs.
I have replaced the ECM
Switched MAF's
Even switched out the translator to several stock MAF's with same result.
Checked wiring... The support books I have show that the volts at the MAF plug B should be between 4 and 6 volts. I have only 2.77. the pink/blk volts are in the low 12.x's and the ground wire seems OK.
Is this one of the ways the extender chip or translators adjusts for the max of 255 on the stock MAF??
In my other car with different chip and no translator and either ECM I get 5.2 volts.
In addition to the error code 34, direct scan shows that the MAF signal bounces/ is very erratic at WOT. It can go from 108 to 68 to 112 with same RPM and TPS. I thought it was "noise" and added a relay to the 12 volt signal which corrected nothing. The MAF never get close to 200 at around 22LBS of boost.
HELP!!
Switched MAF's
HELP!!
