SCOOBY DOO
BASED CANADIAN PATRIOT!!
- Feb 18, 2007
PS window not wanting to go all the way up in the proper position while driving...and..."that's a nice Monte/Cutlass you've got there."
Thats funny but so true!........... It's a good thing these cars have awesome engines, because the rest of the car sucks!
I must have the same brand of tires.For me it would be the odd intermittent problem/ or the completely unrelated compound issue problem.
It starts with a low or flat tire.-It always does...
One time I fill the tire and car won't start even though it started the week before and ran fine... Pull the starter, test it, it's fine re-install, no work... (eventually fixed)
One time I filled the tires and discovered that the valve stems were bad. Pulled them off, repaired and car wouldn't start. (fixed again)
One time I filled the tire, and the antenna stopped working, even though it had worked the last time I tried it. Fixed the antenna and seat belt acted up... (fixed everything)!
One time at bandcamp....
great thread.
On the GN I have to replace my ECM harness when I go around hard turns the car cuts off for a moment or if I hit a hard bump the car can stall out. I had to replace the ECM cause of rusty pins Damn T-Tops. Body bushings!!!!
On the WE4 The digital fuel gauge is not reading correctly so I just have to make sure I have a full tank when I go for a ride. This year winter project.
Let's not forget about that swinging right side visor. One day I'll get the repair/stud kit. But then again the whole thing needs to be reupholstered. I'd have to know it will be redone perfectly before I trust someone to redo it.
So,I just keep pushing it back into place.
Only the chubby chick and not the hot chick at Dunkin Donuts likes my car.
Yeah no cupholder in the GN is pissin' me off.
A dead spare module that was bought good 15 years ago got me mad this week, I do sleep well at night though.
If she don't run I don't have to go to work.
