Wow, o-ringed the heads and receiver grooves in the block and using Felpro 1000 gaskets? I'd really like to see a picture of that setup. Usually it's just one or the other with a copper headgasket.
I've heard of using the Felpro 1007 gaskets with receiver grooves in the heads.
The last time I used a Felpro 1000 type gasket (I forgot the #), Duttweiler didn't place any grooves or O-rings in either the block or the heads on my stage II V6 and it held 30 psi of boost with a very lean 12.0 A/F.
I think the Felpro1000 is suppose to be used on smaller bore blocks anywhoot.
rtviper said:Joe you are correct the few runs before I bought it could have been the start but those runs were conservative runs supposedly in the 10.5 range . Well I took the motor apart and it had receiver grooves in the block and o- ringed heads done by weber racing. The gaskets were Felpro 1000s. At first I couldnt see the damage but right between 1 and 3 there was a bend in the ring of the gasket that goes around the edge of the bore opening and a little of the top layer of material missing between the 2 cylinders. The gasket almost looks reusable. I did check all the bolts on the head on tear down and it seems like about 3 of them were looser then the 80 lbs they should have been. That was the only thing I can see that may have caused the problem? The plugs and pistons all look great. One good thing about this is I found pieces of spring dampner in the engine valley and all the seals inside the springs were broken had slid half way down the stems. Luckily the guy who built the motor had installed small screens on all the holes that lead to the lower part of the motor. Every lifter bore had a small allen head bolt screwed into it any ideas?
