SignUp Now!Well I tore the rest of the engine down tonight and all I can say is! Who ever owned it before either knew nothing about Buicks or took it to someone who had their head up their @ss!
As you can see from the pic the filter adaptor was slobered with silicone as well as the rest of the timing cover. The oil passages were half blocked off. Glad it had some pressure at least.
No spun bearings but there was some metal in the pan when I cleaned it. Took the oil pump apart and it looks really nice, considering.
It seems that I've bought the interum block. It's a 20 bolt block with an open lifter valley. Not really and issue but I'd like to know what the deck height is supposed to be. I hope it's the same as the 109 blocks so I can have a little more compression.:biggrin:
I know where this is going.....
I doubt it kid.:biggrin: I'm hoping to do some really interesting things with her.:biggrin:
O, you mentioned the word compression, and it made me shudder...
I think that's because you don't have any kid.:biggrin:
your right, your right, im tired as F**k! been doing nothing this past month exept sitting here bsing with yall..
True, but I now have a cooler adaptor to use if I want to. The great thing is I now have a turbo saver, accusump (gravity fed), and the cooler adaptor. What shouldn't I use now. LOL
Well if you can wait until Christmas we get a 10% discount but I usually find it cheaper on line so it's usually not worth it. You also get a 30% off store stock for 3 days.
That`s true... I will prob get a few dress-up things for the motor... steel mesh hose lines, throttle cable... a bunch of things I don`t really need:biggrin:
Is the motor be ready yet?... What size cam are you going to use for it?
Forget the steel mesh for the lines Jase. You'll regret it later. I've cut a lot of it off and it really sucks.
The cam I have now is the 204/214 Edlebrock cam but I'm seriously thinking about going bigger.
Way over priced Jase. Here's what I'm thinking about.:biggrin: Check their listing and I'm sure you'll find a much better cam as well as allthe parts you need.
PRO STOCK PERFORMANCE CAM BUICK 231-252ci LIFT 472 496 : eBay Motors (item 290468671677 end time Sep-26-10 02:15:38 PDT)
