Just ordered these
Well I have decided to go with the Big Mac's Mark Willams rear disc setup and front as well.. Might as well I already have the all the rear end from them:smile: Just don't ask how much they cost:frown:
SignUp Now!Just ordered these
My daily driver is an 86 MonteCarlo. I put the Hotchkis (part# 515 1101) upper Tubular control arms on it. These control arms accept the larger GM ball joints. This allows you to use the Impala spindles and dust shields, then you ditch the 10" rotor and upgrade to the 12 inch camaro 1LE rotors and calipers. Instead of using the #154 brake pads you wind up running #52 pads which were used on ¾ ton vans, ¾ ton trucks, impalas, ETC. The difference is incredible.
Things needed:
Hotckis control arms
Larger implala upper ball joints
Spindles calipers and rotor assembly off of an 81-88 Impala. I think chevy Astro van will work to.
On my wifes Buick I installed the Wilwood front brake kit. This brake kit is more focused on leight weight drag racing as the pads are much smaller than the ones used on my MontecCarlo. However it has a four piston calipers and should stop reasonably better than the stock set up. The caliper pistons do not have dust seals which discourages me from using them on a daily driver.
The install of the Wilwood kit is fairly simple. You drill and tap the holes which hold the dust shieds onto the spindles out larger. Then a bracket is mounted onto the spindles. The four piston calipers are mounted to these brackets.
Here is a finished picture of the install.
Hey Sam, does it matter if the impala had a police package or not? I keep reading that you have to have a specific spindle for the 12" brakes because some came with 11" brakes??? Also, did you use the ball joint that came with the hotchkis a-arm? Or did you have to upgrade that to the larger one?
Scott,
Spindles were purchased from "Left Hander Chassis inc" phone number: 815 389 9999
LH part number 00122546
Rh part number 0122547
Calipers are wagnor part numbers:
CR98670
CR98671
Brake rotors are:
BD61967
Oil seals:
CRS19753
Bearings:
BR6
BR3
I am using these upper ball joints:
Moog part number K5208
Hope this info helps you out
So all in all, the only other thing needed is the hotchkis or other comparable a-arms? In your first post, you said you went with 1le rotors and calipers. But here you say wagon calipers. So then did you go with 1le rotors and then the wagon calipers? How is bump steer by the way?
I just remember 1990 for all my transplant parts: F Body 1LE 12" rotors, B Body spindles, master cylinder, calipers, and pads, F Body V8 radiator (don't have it yet but one day), and Ford Crown Victoria for my rear 11" drum brakes.
I found the article that Sam was talking about and I have actually changed my mind and decided to go this route. Going to hit the junkyard this weekend for the B-Body spindles. Here is the article on the buildup.
Big-Brake Upgrade For GM A/G-Bodies- Car Craft Magazine
Info on the Crown Vic 11" drums please. Is this on the stock housing or on a
9" conversion? How hard of a swap is it? I searched and came up empty about it.
Thanks.
There is another article where they pulled .98 Lateral G on a road course from a Cutlass which has this conversion done to it.
