SignUp Now!I was thinking 150.00 shipped with pigtail
I have not had a chance to install it but I was thinking about the return line also
asloan, still selling these?
Wow! So, return fuel flows through the sensor? That is much more substantial than I had envisioned! At least we know what one looks like now.
Thanks for photo NOVI2000.
Conrad
Those ports look awfully small on the sensor. I wonder how much it would restrict a -8 line.
Probably could just use a couple -8 "Y" fittings on the return with one side going through the reduced size sensor and the other staying -8an and then going back down to one.
Yeah I thought of that when I posted! Good idea! I need to start looking for one of these in the boneyard!
Its probably what I'm gonna do with mine. So when you takin the ride out here?
I presume that you are using a fuel pressure regulator.
If you have a bypass fuel pressure regulator, you would install the sensor in the fuel return line circuit. It will work well enough and won't restrict fuel flow to the engine.
