Fuel Sensor for XFI
I have not had a chance to install it but I was thinking about the return line also
I was just wondering if the Taurus sensor would work? A friend running E-85 in his supercharged Mustang is planning to install the Taurus fuel sensor in his car. He is using a FAST system as well.
The Flex Fuel Tauruses are easy to spot. They have a little green flag type emblem on the front fender aft of the front tire. And ONLY the 2 valve engines were Flex Fuel. They only made millions of these. They should be plentiful in the junkyards.
Conrad, please confirm if these are also usable when talking with Jay.
I just (11/26/2009) sent an e-mail to David at FAST asking about the Taurus sensors. Will let you all know when I get a reply.
Conrad
"Hot Air"
Wow! So, return fuel flows through the sensor? That is much more substantial than I had envisioned! At least we know what one looks like now.
Thanks for photo NOVI2000.
Conrad
Those ports look awfully small on the sensor. I wonder how much it would restrict a -8 line.
Probably could just use a couple -8 "Y" fittings on the return with one side going through the reduced size sensor and the other staying -8an and then going back down to one.
Yeah I thought of that when I posted! Good idea! I need to start looking for one of these in the boneyard!
small ports
I presume that you are using a fuel pressure regulator.
If you have a bypass fuel pressure regulator, you would install the sensor in the fuel return line circuit. It will work well enough and won't restrict fuel flow to the engine.
I am using a fuel pressure regulator.
What do you mean by a bypass fuel pressure regulator?
Can someone explaine to me how this would get setup to work with XFI, parameter wise, settings ect...
