Dude, I layed it all out there for ya in that other thread already
I have 4 of the dual element crank sensors, one of 'em is bound to work. I have one S2 damper with the dual ring interrupter setup for the above sensor. That's all you would need to run the ignition it sounds like. No cam sensor required then. I still plan to verify that asap, prolly by Mon. I have a digital pattern generator that will serve, and a 4 channel DSO to verify the results. Looks to me like the sensor assy will bolt right on, but need to verify. The interrupter rings go on with screws as as opposed to the stock press on ring. Not sure if that's a big issue or not.
This week I've been workng the TH400 swap issue, so the other stuff has lapsed a bit.
If you'd like I'll bring it in and shoot a pic of the stuff.
TurboTR
TurboTR
