Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
Its got me thinking also. I had some cam/dist gear problems to the point that it cost me a win in the finals. A dry sump in TSM is prohibited and an external wet sump would be hard to package running it off the single belt that drives everything else. (also per the rules). This cover/pump would solve my problems.
I have a couple of ?s I'm assuming the open end on the bottom left is where the filter adaptor goes. Could you add a plate there to use an external suction? Or are the cavities for supply and return to the filter?
It would be easy to have a suction and a discharge adapter made to fit. Block off the suction on the block or in the cover itself and route the line to your oil pan for an external suction line. You can also have a external pressure line but I'm not sure how you would keep the pressure by-pass. I'd have to think a little more on that one...
Not pictured is the oil filter adapter that bolts to the side of the cover.
Original FWD oil filter adapter that you will have to make with an external suction/pressure adapter.
