so i fixed a couple of vaccum leaks put my new powerstroke ic on. put in a new 340m pump, racetronics hot wire harness, fuel filter, and fuel pressure regulater and also put in a razor alky kit and and tt chip. made a couple wot passes to test everything out and noticed the my o2 reading on the scanmaster were between 650-700. Fp is at about 45psi line off. and im running about 24psi boost. not sure were too look if almost all fuel parts are knew. can someone help
