J-B Racing
Forced Induction
- Sep 16, 2003
Copper gaskets with wire orings is even older technology than the 1007s. Funny how the old tech keeps bouncing back, isn't it.
What works always come back now and then...:smile:
SignUp Now!Copper gaskets with wire orings is even older technology than the 1007s. Funny how the old tech keeps bouncing back, isn't it.
My arp studs don't take an allen tool.![]()
(Read down further and noticed it was already mentioned)
QUOTE]
Sorry Don I didn't see that.![]()
If you're going to try a double seal deal, I would start off with the embedded wire SCE copper gaskets and oring behind the embedded wire.So what is the story on cometics? What are they made out of? How thick? Do they require a re-torque? I hate to machine off my receiver grooves Because I'm afraid I might not be able to go back with them. The heads have allready been surfaced once on the left & twice on the right.
What about wirelocs AND o-rings for a double seal? It looks like there is quite a bit of room inside the wirelocs to do this.
The thickness of the gasket you should use is soley dependant on your target static compression ratio. Figure out what CR you want to run, then do the math to figure out what cc value you need the gaskets to give you to come to your target CR.Anyone have any comments on the RJCs? What thinkness does everyone use on RJCs, or Commetics? I realy dont want this thing to leak water or oil when I'm done. What would you guys recomend? I'll be useing ARP studs.
