Megatron _ed
- Mar 9, 2015
Hi Everyone:
I own a 1989 Turbo Trans Am with less than 6,400 miles on it. Last year, I converted to E85 and this year, I had the car serviced and tuned by Rick (TurboBuRick), who knows a lot about these engines.
Here are a list of mods:
1. Upgraded "wide" intercooler
2. Down Pipe (closed for this test run)
3. 80lb Siemens Injectors
4. DW300 pump
5. TA49 Turbo built by Brian (Bison)
6. Adjustable wastegate
7. TurboTweak chip
8. LS1 MAF
9. MAF Translator
10. Scanmaster and Powerlogger
11. Beefed Up Trans from Jimmy's
THE BOOST IS SET AT 25LBS
During the summer, the car ran fantastic. Would haul ass and no knock retard. Recently, during hard acceleration, I register a little knock retard. So, I decided to hook up the Powerlogger to get detailed results; a file is attached below. Please note, I already adjusted the timing 1.75 degrees in high gear (parameter 4), but that does not seem to do anything since the knock is he same as it was before the timing adjustment.
Here are most of the readings on the file. I only measured the readings at peak knock retard (3.5). For safety, I let off the gas as I saw the knock retard pop up.
Boost - 23.8
IDC - 71.5
IAT - 96.8
TPS - 4.40
RPM - 4550
MAF - 254
LV8 - 255
IPW - 18.8
MAP - 265.5
BAT - 13.8
MPH - 52
O2V - .835
ADV - 22.9
BLM - 128
INT - 128
Knock counts were 7.
I do have a FP gauge, but could only keep my eyes on so many things at once. However, I am lost. My injectors seem to have a ways to go on capacity. Could this simply be that Chicagoland area stations have started converting to E70?
4. DW300 pump
7. TurboTweak chip
8. LS1 MAF
9. MAF Translator
Boost - 23.8
IDC - 71.5
IAT - 96.8
TPS - 4.40
RPM - 4550
MAF - 254
LV8 - 255
IPW - 18.8
MAP - 265.5
BAT - 13.8
MPH - 52
O2V - .835
ADV - 22.9
BLM - 128
INT - 128
