I've been watching this tread for awhile now and I personally replaced my high and lows with "salvania silverstars". I always thought they were bright enough, but now I'm curious.
Does any anyone know how much of a difference between the HIDs and the silverstars might be?
"Davelostmissing" sent me a nice diagram of how to hook up the HIDs so they all light up. He shows the driver side stock connector (high and low) hooked up with a diode to a relay, then from the relay one side to the battery then one connector to the high and low beams of the HIDs, then from there to the battery........what I'm confused about is do I use only ONE relay per pair of HID lights running from the stock outside connector that powered the original Halogen high/low beam and just tape up the original connector that powered the high beam Halogen? In other words, one relay per pair and one diode per pair of HID lights. Also, should I use a 30 amp relay or a 40 amp relay?
John Spina...I sure wish you'd chime in on this one........you know you're the best on these matters so would you help an old dying man here?
I ordered both sets from Peter a week ago, so hope they get here soon.
Bruce '87 Grand National
Dave's diagram shown below:
After reading the above....this is for lowbeam all the diode does is let the lows stay on when the low beam circuit turns off....thanks guys.Maybe I am reading this wrong but the relay is turned on by low beam and the high beam just feeds on top off it,so it all 4 headlamps at all times? Unless this for the highbeam circuit only.
Peter, finally, thank you! Now I've got it thanks to the diagram. Only problem is, at least for me, is the wiring diagram on the pdf you sent is blurred....I can't read the relay numbers, nor the words on the diagram....can this be clearer in some way so I can read it?
Also, do you have a status on my order, Peter? I ordered on 22 November and hope to see the set sometimes, so please let me know if you don't mind. Thanks.
Steve, I can't use Silverstars or original high beams as I've got the HID high beam now on order......but not problem.
Finally, I've got the solution to how to wire up this system and I sure do appreciate it............there was so much discussion on the wiring set-up that I was getting somewhat confused (as always) Now the diagram is here via pdf.
Thanks for the help...........it's much needed and appreciated!
On another note for those that want to use all 4 HIDs when the hi s are switched on the balasts are gonna take up 2 60 secs to reach full brightness....so maybe best to run OEM bulbs or silverstars on the highbeam and do the above mod.
Nope only in general. I don't have my high beams installed yet.Are you talking about our kits? No way do the highs take that long. Also, the people that are going to the 4 ON conversion, they have the advantage of the low beams being on already.
John, Dave or anyone else, I've just got one more question to ask of you before I begin this installation, please help me understand.
In the below diagram sent by Dave, the stock high/low plug is being used for both high/low beam Hids on right and left side of Grand National, or does this show the high/low beam AND the high beam HIDs used on only the left side..............so I would have to repeat this on the passenger side...................right? Or:
In other words, this diagram pertains to ONE SET of high/low beams (right and left) or is it showing the left side only using the high/low beam AND the high beam HID?
So I should just tape up the stock high beam plug since they look like they are not being used.....please tell me if this is correct.
Could one of you guys set me straight here, please? Then I'll behave. And thank you kindly, as so far you've all been such a great help to me.
davelostmissing hit it on the head.
That diagram is accurate and will work just fine. Key to it is, use 14 gage wire and GOOD crimps throughout, a 30 amp SEALED relay, and probably a fuse link instead of the fuse/breaker (just my personal preference) and you should be good to go. One relay will control both ballasts without too much worry and the diode back-feeds the low beams when the high beams are selected.
