Hooker headers
dank GN
BlackArts Automotive (661)993-8277
Okay I know everyone is against hooker headers. I warped my stock driver side header welding it with out bolting them up dumb ass. Anyway my buddy is going to give me some hooker headers my car has ported stock heads and have been running mid-low 11s . Will these headers hurt me ? I know it will have a little trouble spooling the turbo 6765. Also how can I line the bolt holes up on my stock ones ? Heat them up and bend them back?? Let me know what you guys think thanks again .
I'd hit Bison up for advice, he's seen by far the most turbo & exhaust combo's and has data to back it.
The headers won't slow you down if you can leave at high enough boost but they will definitely spool slower than the stock ones. If your manifold is warped you can fixture it and resurface it.
If you want to do a little fab work you can also shorten the drivers side hooker and use it as a replacement. You'll need to make the downpipe hook up but it should work ok.
I got the hookers but my other buddy luckily has a set of stock ones that he is selling me
I'm still curious about the hookers I might try them out for the hell of it
I had them on a stock car. (Came with them) gotten off as fast as I could.
currently cutting it the F loose
Your not going to like them! My son had them on his car for a year then took them off. His build was close to yours. Slow spool on the turbo....O2 sensor would cool down at idle.
02 issue happened on mine as well.
They're terrible.... I have a set of them. If you're interested you can have them for free. I also have a set of T/A ss 3 bolt flange headers that have about 300 miles on them. If you're interested in them make me an offer.
